Main > Project Announcements
Marvel Vs Capcom Renovations - UPDATED 05-24, CP WORKING
Pages: << < (2/13) > >>
CheffoJeffo:
CP comes off, although you may need to get through the coin door to unlatch the panel clamps (which, if there are no keys means drilling).
IIRC that CP is held on by panel clamps that you reach via contortion through the coin door ... or was it bolted on ? I can't recall because I bought that cab for a friend and just loaded it into his pickup.
Someone will know ... common enough cab in the 90s
Thenasty:
if thats a 25" monitor, give or take about 30" wide and roughly 7-8' tall. Lying it in a Durango on its back, will fit if you have a celarance for 8' (lying on its back).
CheffoJeffo:
--- Quote from: Thenasty on April 07, 2010, 06:08:01 pm ---if thats a 25" monitor, give or take about 30" wide and roughly 7-8' tall. Lying it in a Durango on its back, will fit if you have a celarance for 8' (lying on its back).
8 feet tall  ???
The tallest cab I have is a Big Blue (which is taller than that cab) and that's only about 6'4".
The 30 inch width is pretty much on (28-29" is about right to keep clearance under 30").
Thenasty:
I know 8' was tall but I was going for making sure it fits in the durango with some spare.
CheffoJeffo:
The challenge for him will be the depth of the cab on its' back -- I think he'll need to go on its' side (usual provisions for checking for loose parts, etc applies).
Go to full version
