Main > Project Announcements
Marvel Vs Capcom Renovations - UPDATED 05-24, CP WORKING
Pages: << < (6/13) > >>
WhereEaglesDare:
so by adjusting the red, blue, and greens I can get it a lil brighter?  and thanks for all teh help, so the Jamma B board box has an internal battery that I guess allows it to hold programming?  What type of battery?
eclipso:
Let me find you some information, I would type it all out but im working at a DR site tonight and these Dell keyboards suck for actually typing on.
Edit 1
http://www.jammaboards.com/store/cps-2-battery-replacement-kit/prod_65.html
They last about 5 years and they do make battery holders however I have read horror stories about the battery coming just loose enough to where it will kill the board still.
http://en.wikipedia.org/wiki/CP_System_II
Will give you some decent information about the system capcom used with those boards.
Jack Burton:
The Black level adjustment will adjust the brightness of the screen.  Be careful with it though.  You don't want to adjust the brightness and contrast so high that it causes blooming.  That can damage your monitor over time.
I suggest reading some tutorials about how to properly adjust black levels and contrast, and then using the service mode of the game and color pattern test.
WhereEaglesDare:
That would be so awesome!  :notworthy: :notworthy: :notworthy: :notworthy:
 I also noticed when I adjust the V it makes it taller to take up teh screen but as I get closer to the bottom it starts to double over on the bottom...
Where would one get a service manual for this cab?  The inside of the cab has a 1991 date on it but the game wasnt released until 1998, also whoever has been servicing this thing need to get fired, is it normal to leave unshielded wires laying around?  I'll have to post pics of the condition of the wiring later, I guess they figure if it works and no one will ever see it then why bother...
How do I get into service mode?
eclipso:
Instructions are attached!!
Im just going to add onto this and attempt to not double post, are you saying that the verticle is not taking up the whole screen by default or when your playing with it to play with it?
And if you didnt see in my post above eagles I added another link for you to check out.
Here is a vid that should help you understand the basics of monitor adjustments although I am having trouble finding one on proper black / contrast adjustments...
http://www.arcaderepairtips.com/2009/10/14/adjusting-an-arcade-monitor/
Go to full version
