Main > Main Forum
installing arcadevga prior to connecting...
Epyx:
Where I am confused...
You are using soft15khz to run your ArcadeVGA on an lcd monitor?
Using the LCD you should be using the DVI connector. Since you already have tried the LCD on your vga port you may have your driver thinking you have two monitors now and thus the power saving mode initiation of your lcd via the DVI port. Using your arcade monitor to set the monitor to extended and it should appear on the LCD...then set that as your primary.
The problem with using an LCD is you will not get the 15khz modes looking nicely...just stick to your arcade monitor imo. Or use any other video card with the LCD. IE no advantage to LCD on an arcadevga.
sunnywala:
a couple of my posts state that I'm using a WG 25K7197
I was using the LCD to install the card and drivers. I did alot of extra work to NOT play on a LCD.
Ultimarc sites says the arcadevga card may not work with all Dell PCs
I'm afraid Marc wont be able to help me. Unfortunately I bought the card without reading that part
any reason why the monitor would display like that with the nvidia card and soft15?
Epyx:
--- Quote ---a couple of my posts state that I'm using a WG 25K7197
Ah! That explains it then :)
Now I understand...sorry for being slow to catch on.
I had a similiar issue when using my LCD to install drivers and then switching to my WG D9800...the problem is as I alluded to in my previous post. Your ATI driver now thinks you have two monitors connected...your LCD is still thought of as your primary so when you plug in just your arcade it goes out of sync...
You will need to have both connected and switch over to make your Arcade monitor your primary..I did this as well and it was fine after that. If the LCD wont work as you stated because of a Dell incompatibility you will need to temporarily use a higher resolution monitor to adjust the driver setting...or remove it in safe mode and reconnect using only your arcade monitor.
As for the Nvidia...which card are you using? That plays a *big* role in determining success with Soft15khz...also what Nvidia driver?
There is a thread that Sailorsat has on the german site that shows which cards are compatible and with what drivers or if a dongle (newer nvidia cards) is required.
sunnywala:
the nvidia agp card was crap, probably came with the pc in 2000
found an old pci ati card laying around... plugged it in installed soft15
BANG its up! finally! that was at 2am last night!
(just need to install the drivers to get the right res, its only giving me 720x480 right now)
now i see the project finishing in the next week or 2
just waiting for a replacement joystick from divemaster...
and plexi for the cp
oh and wiring the ipac :dizzy:
Thanks Guys
CathalDublin:
--- Quote from: sunnywala on April 07, 2010, 11:12:51 am ---
Don't you have u360's?
--- Quote from: ultimarc ---It has a built-in 8-button interface
