Main > Project Announcements
First Cab JankityCade (Working Title)
Silas (son of Silas):
Coming along nicely.
What are your plans for paint/laminate/graphics etc?
HanoiBoi:
Looking good edge! How 'oversized' are you looking to make it?
Also, do you have your control panel drawn up yet?
edge10:
Thanks for the kind words.
Definitely going to paint it black, more than likely a space theme.
It is 26" (counting the sides 27 1/2") wide a couple of inches deeper than
a regular Asteroids cab and the same height (if you take away the added wheels).
Here is the basic layout that I am planning to use (the gray circle on the upper right
is the spinner).
BurgerKingDiamond:
The cab's profile is pretty interesting, the way that it projects out so much. Is the monitor going to be recessed alot?
edge10:
The idea is to have the glass sit right about on the red line.
The screen will hopefully sit right behind that.
For reference is an Asteroids cab picture scoured from somewhere on the web.
