Author Topic: Does Virtua NBA (Naomi) work on any emulators?  (Read 6748 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
« on: March 26, 2010, 02:23:29 pm »
If so, which one(s)  And which emulator is generally the best for Naomi games?
Thanks.
lilshawn
  • Last login:Today at 10:44:31 am
Re: Does Virtua NBA (Naomi) work on any emulators?
« Reply #1 on: March 26, 2010, 02:36:52 pm »
"Demul" and "Chankast" are of the very few Dreamcast/Naomi/atomiswave emulators out there.
FYI: Naomi = Dreamcast = Atomiswave they are all based on the same CPU
ptinolv
  • Last login:January 20, 2024, 01:37:18 am
« Reply #2 on: March 27, 2010, 01:55:18 pm »
In my opinion Makaron is the best naomi emulator out there. It emulates most of the games very well. I run demul for games that don't run fast enough on makaron or that are for vertical screen (mine is horizontal and makaron cannot flip the screen). Nulldc has also a decent naomi emulation but last time I check you couldn't make the 2nd player work.
Red
« Reply #3 on: March 27, 2010, 03:07:28 pm »
Great.  Thanks.
Can you use the MAME roms for the Naomi versions of Makaron, Demul and NullDC or do you need Naomi specific roms?
What are your system specs that you are running these on?
ptinolv
« Reply #4 on: March 27, 2010, 05:37:32 pm »
My computer is a core2duo 2.4GHz, 1G of RAM and runs XP. There is mainly marvel vs capcom 2 that cannot run full speed on makaron.
On naomi you have 2 types of games : the cartridges games and the gd-rom games (the one with a a chd file in mame).
Makaron can now read the cartridges games of mame but you need a .dat format for the gd-roms games. You can convert the mame chd files to .dat files but it is a little complicated.
Demul can also run the cartridges games of mame and has a .bin format for the gd-roms games.
I may be wrong but i don't think nulldc is able to run cartridges games and has also a different type of roms for the gd-roms (.lst)
And to answer your question Virtua NBA seems to be working on the last version of makaron using the mame rom virnba.zip. I don't know about demul.
« Last Edit: March 27, 2010, 05:48:57 pm by ptinolv »
Red
« Reply #5 on: March 27, 2010, 06:23:11 pm »
Good stuff.  Much appreciated.   :cheers:
I'm looking to set up Makaron in the next few weeks, so I'm trying to get all the info. I'll need beforehand.
I've got a 3.0GHz HT P4 with 1GB RAM and also a Core 2Duo 2.4GHz with 1GB RAM, both running XP.
What kind of performance will I get with the 3.0GHz HT P4?
What kind of video card do I need?  I'm not looking to spend big bucks on a video card, something mid-range.
One more thing, Do any of the Naomi Emulators allow use of a joystick/gamepad on their own or do you have to use a program like XPadder or Joy2Key?
« Last Edit: March 27, 2010, 06:25:34 pm by Red »
ptinolv
« Reply #6 on: March 27, 2010, 09:11:23 pm »
I couldn't really tell what minimum configuration you need to run the games. But if it doesn't work on markaron try demul or nulldc. My graphic card is an ati 3870 and i would say you don't really need a high end video card.
You can configure a pad in demul and nulldc. Makaron only accepts the 360 gamepad for windows. I personnally use Xpadder with it.
« Last Edit: March 27, 2010, 09:18:10 pm by ptinolv »
