Author Topic: RGB LED holder/socket  (Read 6188 times)
Franco B
« on: March 24, 2010, 07:30:35 am »
I have quite a few RGB LEDs to wire up for a project and I want to be able to plug the four LED legs into a socket, something like a four terminal of [this].
I have been looking at a few websites like digikey but i'm not sure exactly what sections I should be looking in. What is this type of thing called, a header pin cable? There seems to be a few similar products but with different names.
I think the pitch of the LED pins is approx 1.27mm (0.050")
Does anyone know where I might find something like this?
whammoed
  • Last login:Yesterday at 09:05:02 am
  • Crack don't smoke itself
    • NiceMite
Re: RGB LED holder/socket
« Reply #1 on: March 24, 2010, 10:23:41 am »
That looks like a standard 0.1" pitch connector.  Doesn't look like something specific for LEDs.  Same thing you would use to plug the power button, hard drive led, etc into a PC motherboard.
I'm not having any luck finding a similar 0.05" connector at the usual places.
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #2 on: March 24, 2010, 11:00:58 am »
hmmmmmmmmmm
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: March 24, 2010, 11:21:32 am »
hmmmmmmmmmm
Yes, I made the same sound.
Franco B
« Reply #4 on: March 24, 2010, 11:54:18 am »
They can be used for LEDs. If you follow the link they are advertised as LED holder/sockets but you are right they do look like/are the common JST etc connectors.
I had been looking for connectors at some places but like you I wasn't coming up with much, I thought I may have just been looking for the wrong thing but if you can't find anything either then I may be SOL.
hmmmmmmmmmm
Nothing to see here, more along please ;)
whammoed
    • NiceMite
« Reply #5 on: March 24, 2010, 12:00:14 pm »
Yeah, I'm sure they work fine for LEDs.  LEDs seem to have about the same leg size as the 0.1" header pins.
It may be that it would be difficult to make a connector with crimp pins spaced at 0.05".  That's awfully close together and there wouldn't be much room in between the pins for the housing.
Franco B
« Reply #6 on: March 24, 2010, 12:14:11 pm »
Yeah thats kinda what I was thinking too. Hmmm. Oh well, I'll just have to keep them soldered. Thanks for the help.
whammoed
    • NiceMite
« Reply #7 on: March 24, 2010, 12:16:43 pm »
I suppose you could use two of those connectors and bend two LED leads (1 and 3) slightly forward and bend the other two (2 and 4) slightly back.  The LED would not "snug" up to the connector of course.
Franco B
« Reply #8 on: March 24, 2010, 12:34:46 pm »
Yeah I have been thinking about that. I'm not sure how neat it would end up looking and it may be a bit bulky for what I want.
I think I may try and get some flat cable with a similar pitch and solder that to the legs.
Encryptor
  • Trade Count: (+34)
« Reply #9 on: March 24, 2010, 05:44:49 pm »
Franco,
Is this what you're looking for?
http://tinyurl.com/ycyr2tj
Encryptor
Beley
  • Last login:September 14, 2013, 09:02:37 pm
« Reply #10 on: March 24, 2010, 08:17:08 pm »
Not shure if its exactly what you are looking for, as these arent pre-wired, but...
digikey part numbers: H2181-ND (housing) and H9992CT-ND (contact)
connecters are allways a pain to find.
whammoed
    • NiceMite
« Reply #11 on: March 24, 2010, 11:57:54 pm »
Good find.  I didn't think to look for a slightly different size.  (0.05" vs 0.049")  Got to be close enough.  Pretty inexpensive too.
Franco B
« Reply #12 on: March 25, 2010, 02:19:20 am »
Franco,
Encryptor
Thanks for looking Encryptor but they are 0.100" pitch.
Nice find  :cheers:
I was having a think last night and I thought of a better way to wire them without using pre-wired connectors. However, as these are not pre-wired I can hopefully use the better wiring method in conjunction with these  ;D
The price is great too. Good job as I need 50+
Edit: £12 shipping is a bit of a biatch but even then 100 sockets and 400 pins only comes to £28.64 shipped which works out to less than 30p per socket and four pins :)
Thanks everyone for your help :)
« Last Edit: March 25, 2010, 03:13:18 am by Franco B »
« Reply #13 on: March 25, 2010, 09:37:04 am »
Hmm...
50+ sockets...
So 50+ RGB LED's...
HmmmmmmMMmmMmMmMmmmMmMmmmmMMmm....
Franco B
« Reply #14 on: March 25, 2010, 09:49:15 am »
Its nothing too exciting I'm afraid, don't get your hopes up :P
Ginsu Victim
« Reply #15 on: March 25, 2010, 09:51:54 am »
The ultra LEDildo?
  • Last login:May 06, 2024, 04:31:28 pm
« Reply #16 on: March 25, 2010, 09:54:54 am »
Too late!   ;D
ubiquityman
  • Last login:May 06, 2016, 10:57:58 pm
« Reply #17 on: March 25, 2010, 08:29:20 pm »
I'm doing exactly that with 5mm LEDs.  The spacing is about 0.1 and the sockets are small enough to hold the LED legs securely.
You can get the connectors from action-electronics.com
It's relatively cheap, but shipping is expensive.
