Main > Main Forum
RGB Driver/Wires Question
MB:
I second that!
Just bought some RGB drives and a LEDWiz so I'm glad this post came along.
I'm pretty good with electronics but even with the supplied docs it would have
taken trial and error to hook everything up.
studmuff:
Thanks for everyones responses. On friday before I headed down to the MIdwest Gaming Clasic I setup my LED-Wizs. I only used 24 of the outputs per LEDWIZ and connected the 5 volts from the rgb drivers to the USB 5 Volts on the board. Working great. Setting up LEDBlinky was pretty easy once I followed the PDF instructions. I set up MAME and now I just have to spend the time to set up the other emulators and tweek things the way I want them. The voice saying the controls is very nice although I want to download a different voice as the lady I have is annoying. Does anyone know good sites for these voices? I think it was stated in the PDF where you could download others but I'm not in front of it at the moment.
Hoopz:
--- Quote from: studmuff on March 30, 2010, 11:45:39 am ---Does anyone know good sites for these voices? I think it was stated in the PDF where you could download others but I'm not in front of it at the moment.
Try this thread:
http://forum.arcadecontrols.com/index.php?topic=101336.0
DeLuSioNal29:
For GroovyGameGear.com's RGB LEDs:
(1st wire) Red Wire = +5v source - Connect this with the following to form that color:
(2nd wire) = Blue LED color (ground)
(3rd wire) = Green LED color (ground)
(4th wire) = Red LED color (ground)
Additional colors:
(2nd wire) + (3rd wire) = Light Blue color (ground)
(4th wire) + (3rd wire) = Yellow color (ground)
(4th wire) + (2nd wire) = Purple color (ground)
(4th wire) + (3rd wire) + (2nd wire) = White color (ground)
I have a video that I did showing wiring and how to power them by using a power supply (without an Led Wiz installed). May be useful for you. I've also listed color combos above as well.
DeLuSioNaL29
arzoo:
--- Quote from: studmuff on March 30, 2010, 11:45:39 am ---The voice saying the controls is very nice although I want to download a different voice as the lady I have is annoying. Does anyone know good sites for these voices?
AT&T Labs Natural Voices sound fantastic - but I don't think they can be downloaded for free. Try searching google for Free TTS Voices.
