Main > Main Forum
Aimtrak problems
Cananas:
--- Quote from: Paul Olson on March 18, 2010, 10:38:53 pm ---you have to enable Lightgun in mame.ini. Also set lightgun_device to mouse.
Short answer: No.
Long answer; explanation:
If you have "lightgun" enabled, you can use the lightgun axis and button to redefine keys in MAME. If you don't have lightgun enabled, you can not use the lightgun.
"lightgun_device" is to asing a control device to the MAME lightgun. Internally, this option overrun the control device enable/disabled, enabling it. For Aimtrak, the option must be "lightgun_device lightgun.". This also will change lightgun to 1 ("lightgun=1") when you run a game that uses a MAME lightgun controller.
You don't want lightgun_device mouse, because then you couldn't reload shooting offscreen.
Paul Olson:
--- Quote from: Cananas on March 20, 2010, 04:16:45 am ---
Short answer: No.
My offscreen reload works just fine with it set to mouse.
To get the trigger to work in MAME, assign the trigger to button 1.
I haven't used MAME32, so I can only suggest what my working settings are in MAME.
MK3FAN:
Well, I have a new problem now. The whole damn thing quit working. I have to unplug it for several minutes to get it to start working again, then after a few seconds, it stops. I restart the computer, still nothing. After several attempts at plugging and unplugging the cables, it again starts to function but only for a few seconds, then stops again. This is all outside of Mame. I've about had it with this thing.
MK3FAN:
Now it appears to have died all together. I tried the system on 3 different computers and it doesn't work on any of them. I either received a malfunctioning unit, or something happened to it that I am unaware of. Regardless, thanks for the suggestions and I most likely won't be buying another one.
Paul Olson:
Email Andy. He will take care of it. I am pretty happy with mine, and although it took a few tries to get it calibrated, it works well.
