Main > Main Forum
Having trouble configuring Q*bert on MAME for four way diag on a U360
Pages: << < (2/2)
Diewrecked:
I did indeed create these maps as qbert.ini files in the INI folder :)
Sorry Ubiquity that last map you suggested just causes the character to not move again.
I'm wondering if there's a way of using an Ultramap map for this one game but MAME maps for all the others? I don't even know if a known working good map exists that way round?
Thanks for all your continued help..
ubiquityman:
--- Quote from: Diewrecked on March 19, 2010, 09:42:25 am ---Sorry Ubiquity that last map you suggested just causes the character to not move again.
From the sounds of it, I'm getting different behavior than you.
The game works fine for me.
Have you checked to make sure the Ultramap is set to Analog?
What version of MAMEui are you using?
Diewrecked:
--- Quote from: ubiquityman on March 19, 2010, 12:54:22 pm ---Have you checked to make sure the Ultramap is set to Analog?
I've not launched Ultramap since I installed the sticks. I launched it to double check and *cough* it was set to 4-way *cough*
I've set it to analogue now and my second map
joystick_map 444458888.444458888.444458888.444555888.555555555.222555666.222256666.222256666.222256666. works fine! :)
Thanks again for all your help Ubiquity and sorry for being such a total nightmare!!!
Cheers  :cheers:
ubiquityman:
--- Quote from: Diewrecked on March 20, 2010, 05:00:05 am ---I've not launched Ultramap since I installed the sticks. I launched it to double check and *cough* it was set to 4-way *cough*
LOL.  I should have asked if you plugged the joystick in.   ;)
It happens to the best of us.
You were using a crippled U360.  Now you have it set to analog, your games will work much better!!!
Glad you have the problem solved.
Herk:
Ubiquityman,
     I just added your line to a brand new qbert.ini file and I now have a perfectly controlled Qbert.  I had put Qbert on the "this sucks" pile but it's in the favorites pile now.
Herk
Pages: << < (2/2)
Go to full version
