Author Topic: I feel really dumb, but which button is #1?  (Read 1309 times)
Kharn
  • Last login:July 06, 2010, 03:44:45 pm
« on: March 09, 2010, 09:32:50 pm »
I've installed all my buttons, mounted the IPAC, and now I'm staring at all the microswitches on the bottom of my control panel and I cant figure out one thing: In the standard layout, what number is each button?
My layout is two rows of three and then two more underneath:
__X_X_X
__X_X_X
_X_X___
Is it just:
__1_2_3
__4_5_6
_7_8___?
  • Last login:Today at 08:24:26 am
Re: I feel really dumb, but which button is #1?
« Reply #1 on: March 09, 2010, 09:40:33 pm »
yes
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: March 09, 2010, 10:31:24 pm »
Depends on the user.
That's the Capcom 6-button standard, but I go:
456
123
     7
Most people who play my cab for the first time assume the correct button when looking for button one. I don't like reaching across the other buttons for 1-3 button games.
« Reply #3 on: March 09, 2010, 10:39:36 pm »
I'll amend my previous statement. MAME sees it how you have it set in your button diagram up there, but with MAME you can change the keys to your liking
romshark
  • Last login:October 16, 2023, 02:50:59 pm
  • Arcade and Robotics enthusiast
« Reply #4 on: March 09, 2010, 11:23:22 pm »
Of course, if your cabinet can also play real arcade boards (that use more than 3 action buttons), you'll need to go with the "default" mapping. Most real arcade boards can't change button assignments.
But if you're strictly using a PC in your cabinet, just about any way will work (as long as MAME is set up properly.)
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #5 on: March 10, 2010, 01:36:57 am »
nevermind, decided to start my own instead of detracting from your question
« Last Edit: March 10, 2010, 01:47:42 am by shateredsoul »
angryred
  • Last login:October 20, 2023, 12:46:57 am
« Reply #6 on: March 10, 2010, 06:48:36 am »
456
123
     7
Yeah, that's what I did too (except my 7 is on the opposite side, right hand thumb).  I had to remap all the buttons for Street Fighter style games so that punches would be on the top row and kicks on the bottom, but I like my button #1 right where you show it placed.
Ginsu Victim
« Reply #7 on: March 10, 2010, 09:45:59 am »
456
123
     7
When I did that layout, it was because I map the 7th button to button 4, so I have two button 4's. That way, I don't have to worry about the mapping from Neo Geo to Capcom, it works for both. I don't care that the punches and kicks are reversed for Capcom fighters, as I didn't play them much in the arcade to begin with.
So it's actually:
456
123
     4
« Last Edit: March 10, 2010, 09:48:52 am by Ginsu Victim »
