Main > Main Forum
Problem starting MAME games
Pages: << < (2/2)
200X:
Actually there was one error during compiling:
MameUI.mak: 40. warning. overriding commands for target 'mameui32.exe'
makefile. 663. warning. ignoring old commands for target 'mameui32.exe'
Could that be the problem??
Harakiri:
I can't tell if those overrides may be causing MAMEUI crashes, i'm not a programmer. All i'm trying to say is that you can easily achieve the same goal following my workaround.
200X:
--- Quote from: Harakiri on March 09, 2010, 03:17:58 am ---
I found the solution to my very own problem!
If you tried to compile the lastest MAMEUI using MAME compiler and you are experiencing random crashes here's a simple solution:
1- Compile the latest version of MAME
2 - Download MAME+GUI mamepgui-1.5.0.win-20100305
3 - Run the program, locate compiled version of MAME, set the rom directories and other options
There are no crashes with this setup. I noticed that MAME+ emulator by itself doesn't skip nag screens in certain games so i decided to try this setup and it works flawlessly.
Have fun! :)
You mean this one? I tried it and it still didn't work.
Harakiri:
Have you compiled the command line version of MAME?
200X:
--- Quote from: Harakiri on March 09, 2010, 01:36:03 pm ---Have you compiled the command line version of MAME?
Yes, I compiled both. But I think I will give up for now. I downloaded a precompiled version of 0136u4. I guess I'll just have to do without the highscore diff.
Pages: << < (2/2)
Go to full version
