Main > Everything Else
Re: I am now a blackbelt!
<< < (14/34) > >>
Xiaou2:
--- Quote ---after heath took that blow he quikly got to his feet amazingly but his eye and pretty much the whole side of his face was swollen purple just seconds after the impact.
he did not get knocked out from the forehead punch all though it was swollen with his eye nor did his head explode with fajin he got clobbered straight by a large tree trunk of an arm and that was two real mortals in a real fight and what really happens when you get hit really really hard by a huge fist with more power then your average human I would say.
 This says it all.  The guy got back up.   There was a ton of power released... but it
was "dull" enough that it did not cause brain damages, blood vessel ruptures... Not even
a lowly knockout.
 It was a heavy Stream of energy, and not an immediate full mass dump.
 Ive knocked out 3 fighters, all of my choosing.  IE: Not on accident.  Not by chance.
Not after 15 tries.   Single hit KOs  at will.   I was a mere 150lbs at that time... and
I only put maybe 20% power @ 6ft distance.   This is not to brag.  Its merely
to say what happened, and what is possible at the weight level.
 A person with 200+  lbs  with Fajin, would have to be far more careful, because the
level of power would be multiplied to an unthinkable level.   Which is exactly what
happened when the Bulky JKD guy hit me from a mere 1"  thru the 4" phone book,
setting my chest on fire for 4hrs long.  Another inch and I would have been critical.
I almost went to the hospital as it stood, as the pains were unbearable.
 "Dull power" is NOT painless, and can even be fatal.   However, the
same person trained in Fajin, can multiply his power well over 3x, reduce his need
for large distances, and make his strike over  3x  as fast.
 Dull power isnt going to work well for the smaller person who needs to defend himself
and his loved ones.    They simply do not have enough mass to create enough
effect with it.   However, Sharp concentrated power Will work.
--- Quote ---And, btw, turning off the energy (3 on your list) is not going to transfer a greater amount of power any more than turning off a light switch uses more power.
 Fajin is a Bomb. The  MASS  is delivered ALL-AT-ONCE, in a split second.  Once its been transferred, its 100% done.
 I simply wont argue the point anyone.  You do not understand physics well enough... and you are too lazy to read the actual details correctly to make the understandings.
(which causes me to retype the same thing 3+  times.   It will be amazing if you can
actually 'make it' as a lawyer with those kinds of reading skillz)
Xiaou2:
Which one is more Powerful / Preferable:
1)  Full mass delivery  in  .001  second
200
 Or
2) Stream of quickly decelerating Mass over 3 seconds
50 30 30 20 20 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 10 05 05 05 05 05 05 05 02 02 02 02 02 01 10101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101 01010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010 10101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101 01010101010100101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101 01010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101
(This part would go on for several pages if compared in relative time units)
polaris:
if it can be explained by physics as you claim, show me the formula that explains it, not a load of numbers that mean......
nothing
do you understand now its in red and big letters
HaRuMaN:
lol
Cakemeister:
I think what X is describing is what in physics is called an "impulse", which is the integral of force over time.
Consider two punches delivering the same amount of momentum. Punch A is delivered with a much higher force over a much lower time than punch B. Punch B might have a net effect like a push, if it is slow enough, but punch A might have a more damaging effect.
It's sometimes hard to tell what X is saying, but I think that this whole fajin business is how to concentrate the same amount of punching power over a shorter time frame, thus increasing the force delivered. I'm guessing this higher force is what causes X the chest pain, instant death, and other effects.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
