Main > Everything Else
Re: I am now a blackbelt!
<< < (12/34) > >>
northerngames:
--- Quote from: shmokes on March 08, 2010, 12:42:39 pm ---Why in god's name would you ever, ---smurfing--- ever, quote a Xiaou2 post in its entirety?  Are you mad???
believe it or not I don't know how to do a partial quote  :dizzy:
shmokes:
 ;D  I just click the quote button and then delete the parts I don't want.  Then if I want to do multiple quotes I just copy/paste the open quote tag and add another close quote tag.
Malenko:
first off Tyson wasn't so great when he returned to the ring because once little mac figured out the red blink / eye wink , everyone knew how to beat him.
I think I know how to put this to rest. Xiaou, go find an 80 lb woman, teach her how to do your HaDoKen punch and I'll fight her. I'll bet you I win and I am pretty much untrained in anything except Mortal Kombat and street fighter (II) but I have a Killer Instinct
hypernova:
If Xiaou can do a Kamehame-ha, that'd be frickin' sick.
Then I'd also believe pc fans should be sucking air in on the bottom rather than blowing out hot air at the top.
Xiaou2:
--- Quote ---They radiate out 180 degrees from the collision, not 360 degrees.
 Zoom in on the picture.  The lines are greater than 180 degrees.  However, my
apologies for not drawing completely to the edges :P
--- Quote ---  And I don't give a ---fudgesicle--- whether the energy is transferred in a hundredth of a second or a billionth of a second.  The energy we're talking about is kinetic energy, not static electricity (though there likely would be a transfer of that as well).  The transfer of kinetic energy is going to force the object at rest to move in the direction it was hit unless there is some opposing force stopping it.
 This again shows your lack of understanding of physics in the human body.
 The body Will move back some, but the distance a body is moved back is not merely
based on power levels.  Time IS a factor. And so is the material you are striking.
 For example, I can stand toe to toe, and push a person backwards several feet.
However, it would do No damage whatsoever.
 I can also hit a persons belly surface and pull back just as fast, and again... no
damages, as well as no body movement at all.
 I can hit Hard and follow thru for 2 seconds time...  and that person may stumble back
4 to 5 ft.
 Or, I could hit hard with fajin, with a split second release, and the person will only
move back a foot at most.
 There are many things that create greater target push back:
1) Amount of force
2) Depth of Hit
3) Amount of Time the energy is left "on".  (Time the punch is still pushing forwards)
4) Weather the Target is completely limp, or is actually "resistive".
5) Weather the Target person re-directs the energies, such as bending knees - which
changes horizontal forces to downwards shock absorption.
6) The kind of target you hit. Solid bone -vs- Fleshy
7) Type of mass distribution & Center of Gravity.
8) Configuration of Joints / Energy flow pathways
 And much much more. The bodys effects are too numberous to list.
 I can throw a down-diagonal forwards kick at a persons forwards lead leg Knee, and the knee is barely going to move at all. It will compress and stress the joint and tissue... but it has little way too move.
 Without any real in depth fighting experience, its easy to know why you do not
understand these concepts.   Even many experienced fighters may have difficulty
understanding some of this stuff... as something like Fajin, and Tai Chi absorption
techniques, are some of the highest levels of technical abilities out there.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
