Main > Everything Else
Re: I am now a blackbelt!
<< < (8/34) > >>
Hoopz:
--- Quote from: polaris on March 06, 2010, 07:40:14 pm ---
--- Quote from: Xiaou2 on March 06, 2010, 04:51:03 pm ---No.  Its the physics of the human body structure.
  A pool ball hitting another pool ball will cause the hit ball to rocket around the table.
 So yeah, umm...  Your Concept of physics is Flawed,
thus, you are wrong.  Im sorry if that hurts your Egos.
the two poolballs are the same mass you idiot, your hand doesn't have the same mass as a whole human body. if you hit a body with a whole other body at speed the target body would not absorb the impact it would move like the pool ball, for ---smurfs--- sake do you never get bored of being wrong
Now that's some funny stuff.   :applaud:
Xiaou2:
--- Quote ---The more force you hit someone with, the less proportionally that can be absorbed by our squishiness, the more the person will be forced backward.  I'm no physics expert, Xiaou.  I'm just really really smart.  I figured that out all by myself.
 To what end?
   In what point does a punches damage turn to a mere damage-less Push?
 This is the point.
   If you can transfer all your energy in a fraction of a second, you do not need
to keep Pushing deeply thru the target.   Thus, he will not be pushed backwards
much at all.
 Most punchers can not release all their energy fast enough for that
to happen... AND, they simply do not understand that mere depth alone
does not do more damage.
 The fajin energy is like a shockwave, and rather than go merely forwards thru the
target... it will be more spherical.  Again, much like an bomb.  The reason, is
that the target can not deal absorb fast enough, and so the energy burst out in
all directions.
 A typical punch does have some damages that spread out... but usually its
very limited because the energy at Impact, which is the most important time unit,
is only partial release... and the body can absorb it more easily.  As the punch
changes to push... it does no further damages..and most of the energy is merely
a forwards push.
 The Pool ball was en example in the TYPE of Material.   Has nothing to do with Sizes.
The solid high density material is very conductive, and Nothing like how a human
mass reacts.  If you have launch two Human Twins at each other, they wont react
like two pool balls at the same mass as the twins.   Humans have bone, which is like
a pool ball... but because that structure is covered in absorbing tissues, air pockets,
fluids, and even the bones themselves are flexing and filled with joints... the human
structure can absorb and redirect energies in ways that is unlike any pure solid object.
Being as such, you can not apply simply solid object physics to it.  Its a Lot more
complex than that.
shmokes:
--- Quote from: Xiaou2 on March 07, 2010, 03:26:28 pm ---
much at all.
I'm not . . . sure . . . that's . . . how physics works.
Xiaou2:
Visual might help some who have Genuine Interest in Improoving Technique:
 Red Ball       = Fists
 Red Square = Full Mass
 Red Lines    = Force Lines
 Green          = Body (Chest)
 Yellow          = Shows COMPRESSED Tissue
 Top Half Shows Fajin Reaction.
 Bottom half shows traditional reaction.
 Fajin Explanations (Top Half of Picture) :
    Frame 1:  Fists impacts and Compacts tissues until they are fully Compressed
    Frame 2:  Full body mass is then connected to the fist, by a blistering fast
     tightening of every single muscle in the body, to unify ALL MASS at one time unit.
     Notice the Force Lines.  They shoot out in all directions like a spherical explosion.
      The time unit = Instant Force Dump at possibly 1/100th of a second.
 Boxer / Karate Punch  (Bottom Half of Picture) :
1) Fist and Partial Mass are already connected before punch hits.
2) Multiple boxes of mass represent mass that will stream over time.  For example,
1 Arm & part chest mass hits first, then hip/back added by push thru, possible
1 legs last.
3) Because less mass is impacting initially, and over a longer period of time... the
forces are absorbed well enough that the forces stay in a straight narrow line.
With Fajin, the forces are so great, that they force their way in all directions doing
mass damages in order to Try to dissipate.
4) The smaller circles show the force being carried out long after initial impact, as
the puncher is Pushing / Accelerating the person away.  The force lines stay stable
as a stream initially, and quickly die down as speed is reduced via bodys friction
& the targets acceleration away.   The compression of the tissue is also seen reducing
over time.
 Let it be said, that Some Traditional Punchers Can and Do create Fajin.  Usually,
its a random act.. as they do not train it specifically, and thus it can not be called
upon at any instance accurately.
 Fajin can be added to Any kind of strike... including Hooks for example.  Its merely
a technology.  However, because its so powerful, and needs so little space to
utilize.. Wing Chun, and other similar arts... will choose to use the lead hand straight
punch (which is nearest the target) in order to get the hit there faster.. and because
its less likly to be stopped.
 Picture 2
 Shows again the  Typical  -vs-  Fajin  strike.  It shows the Amount of Mass activly
adding to the power of the strike at Solid Impact. (all forwards vectored & fully
connected as One solid unit, in One split second of Time)
 The Red shows Active Use of Mass at Impact
 In the typical punch, one leg, one arm, and various other parts are Not adding
to the forwards vector... and are Not connected as One unit at Impact.  Therefore,
do Not add to the damage potentials.
 In fact, Im actually being Generous with my Active mass on the traditional puncher.
For example, when the hip rotates.. only part of that energy is utilized due to
the mass rotating past a forwards vector.
 Im also creating a pathway for the energy from ground to hand... where as some
fighters lose this path with bad timing..mostly at the hip...  Thus only upper body and
arms are involved.
Xiaou2:
Now that you Might understand what is happening..  Take a look again at a True
Master of Power.
 Notice that when he releases his energy... ALL of his mass is UNIFIED as ONE
Solid Object.   Watch as Every single muscle from his face, to he Legs reverberate
with UNIFIED Mass Force.
 If this man hit you with his full power, you would not make it to the emergency
center.  You would be riding a hearse.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
