Author Topic: Gaussed!  (Read 1092 times)
danr4483
  • Last login:March 29, 2010, 08:57:07 am
Gaussed!
« on: March 07, 2010, 07:14:27 pm »
Hi all,
I finally mounted my monitor tonight and the positioning looks wonderful.  It's great to see the system in there and I'm almost finished.  The big but is that 3 of my corners won't degauss.  Any ideas on how to fix this without buying anything?  If I let it sit for a while and degauss again will it make a difference?  It's mounted with straps, but it's fully covered and nothing is putting an inordinate amount of pressure on the monitor.  It's a regular computer monitor, any help would be most helpful!
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
Re: Gaussed!
« Reply #1 on: March 07, 2010, 07:39:37 pm »
Do you have anything like big speakers close to them?
danr4483
Re: Gaussed!
« Reply #2 on: March 07, 2010, 07:42:41 pm »
Nope, not at all.  :dunno
severdhed
  • RIP Dinosaur Hippo
Re: Gaussed!
« Reply #3 on: March 07, 2010, 09:38:57 pm »
is the monitor mounted horizontally or vertically? i had a 19" crt pc monitor i put in my DK cabinet, when i rotated it to the vertical orientation, i had problems with it degausing.  after about 2 days of leaving it sit in that position and degausing it again, it started working fine.
danr4483
Re: Gaussed!
« Reply #4 on: March 07, 2010, 09:41:37 pm »
It's vertical, maybe I'll try that.  I've had it on it's side for a while when it was on the floor, maybe it is on more of an incline now.  Fingers are crossed that it'll come out.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Gaussed!
« Reply #5 on: March 08, 2010, 08:38:30 am »
Anytime you move a monitor this can happen -- happens on my Joust cocktail everytime I move it. If I'm not patient enough to let it degauss on a cold start (I let it sit for a day), then I used to use a corded drill, but that died and I just use little magnets and move them as fast as I can in small circles (much bigger pain than the drill).
Working: Not Enough
Projects: Too Many
Progress: None
