Author Topic: Does this ball top exist?  (Read 1960 times)
  • Last login:October 20, 2023, 11:39:06 pm
« on: March 03, 2010, 08:21:49 pm »
Question...
Thinking about switching my existing Happ Competion Joysticks with nicer ball top joys.  (I DON'T want U360s - I plan to use those on a future project). That said...
Here are my prerequisites:
1 - Must fit on a 3/4" wood panel
2 - Must mount from underneath
3 - Must be 8-way, just like the comps I already have on there
4 - Would love to have them in blue, red, green and yellow if possible. (optional)
I was looking at Lizardlick's WICO NOS Joystick s(with 4 inch shaft).  But they only come in red.  Would these look OK on a wood panel?  My problem is I'd love a Seimitzsu or Suzo joystick, but they are made for metal CPs and aren't long enough if mounted underneath.
Any suggestions?
DeLuSioNaL29
Franco B
Re: Does this ball top exist?
« Reply #1 on: March 03, 2010, 08:27:54 pm »
I have something in the pipeline. Maybe you would like to help me test it out :)
« Reply #2 on: March 03, 2010, 08:29:25 pm »
Sure, what did you have in mind?  Is it based on HAPP or another technology?  I'm looking for Happ replacements.
Franco B
« Reply #3 on: March 03, 2010, 08:34:04 pm »
I'll shoot you a message with some details in the morning as its nearly 2am here.
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
« Reply #4 on: March 03, 2010, 09:18:56 pm »
You could try a Sanwa JLW with a longer shaft.  Never tried one myself though. :dunno
Epyx
  • "You're an oddity"
« Reply #5 on: March 03, 2010, 11:50:44 pm »
+1
I have a pair from Ultimarc that are going into my current project. I have tested them out on a test board and they are fantastic sticks and very mod friendly. In my current project you can see I got them with green after market balltops that have leds in them.
Check (with some routing), Check (again with routing), Check (4 way and 8 way switch...great feel), Red, blue (2 shades), green, pink, grey, yellow, white + translucent versions for LED mods.
« Last Edit: March 04, 2010, 10:57:03 am by Epyx »
Last Project
Epyx Tutorials:
Tutorials
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
« Reply #6 on: March 04, 2010, 02:53:47 pm »
I got an 8 way Sanwa JLF with red balltop from Lizard lick. Think it fits your criteria.
I bottom mounted mine in my Defender bartop and had to shim it down to get correct, low Defender height.
Grasshopper
  • Last login:November 08, 2023, 07:20:31 am
« Reply #7 on: March 06, 2010, 07:28:31 pm »
If you're talking about the Suzo 500s then you're wrong. They can easily be mounted underneath a 3/4" wood panel.
Although they're designed to be mounted on a metal panel with the pivot visible, I actually think they look nicer mounted underneath wood with the pivot hidden.
