Main > Project Announcements
Ghost n Goblins Scratch build..
Pages: << < (8/10) > >>
Muerto:
Hey.
Checked the +5 and it was 5.32, so adjusted it to 5V:
Power supply:
These are the speakers i´m using, i figured they where ok..??
ammitz:
have you tried to connect them to another audio device to see if the speakers work?
Muerto:
yes, and they work, when i hooked them up to the GnG pcb yesterday they worked...
emphatic:
Hopefully, I'm wrong, but I think you might have busted the amp on your PCB. It all depends on how you've hooked those speakers up though.
Here's some examples on how to do it along with an example of how to not do it. The amp wants to get at least 4 ohms apparently.
This is from a Swedish site, so if you can read that there's even more info here: http://cc.arkadtorget.se/speakers.html
Muerto:
i hooked them up like the drawing in the middle.. - PARALLEL
i see if i can find the schematics of the PCB, and find that amp...
Go to full version
