Author Topic: Emulating a 4-way joystick  (Read 1663 times)
JZSlenker
  • Last login:April 20, 2014, 10:06:50 pm
« on: February 18, 2010, 07:17:37 am »
I know I know, lots of people have already talked about this but I have one more question.  I am fully aware that I can (or could) have put a third joystick in that is an actual 4-way joystick, or I could change the restrictor, or I could buy ultimarcs joystick.  At this point I'm not going to do either of those things.  My question is....   Somewhere I had read the following for a way to make 8-way sticks behave better on 4-way games.
... map your inputs as such
ultimately:
UP = UP NOT UP/LEFT NOT UP/RIGHT
DOWN = DOWN NOT DOWN/LEFT NOT DOWN/RIGHT
etc.
the end result, the game only accepts the "pure" four directions.
if you push diagonal, you get no response.
Now what I did was to map things as follows
UP=UP not LEFT or UP not RIGHT
DOWN = DOWN not LEFT or DOWN not RIGHT
etc etc
This DOES make a marked difference in controllability.!  Would it be better to map it as the post suggests using the same time wording, or is the way I've done it better?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Emulating a 4-way joystick
« Reply #1 on: February 18, 2010, 12:14:38 pm »
...Now what I did was to map things as follows
etc etc
It makes a difference? ???
What are the differences?  Are you using a keyboard encoder, or a gamepad encoder? (Mame does extra stuff with gamepad encoders.)  What game(s) have you tested? (Games handle diagonals differently.)
Logically, what you have is the same as Up = Up.
Why: Your map is Up = (Up not Left) or (Up not Right).  If you press up-left, mame looks at the map and checks if it is (Up not Left); it fails this one, so mame checks the next part.  Is Up-Left (Up not right)? Yup it is, so mame accepts Up-Left as Up.  Mirror for Up-right, etc.
The only difference I can see between your map and the simplified Up=Up is that mame has to do some more logical steps sometimes.
If you want to have diagonals ignored, it should be mapped:
Up = Up not Left not Right.
Down = Down not Left not Right
etc
If you mapped exactly as you guoted, no directions would work, I think.
Robin
Knowledge is Power
JZSlenker
« Reply #2 on: February 18, 2010, 01:28:24 pm »
You are right, mapped as quoted nothing works.  UP=UP NOT LEFT NOT RIGHT works great.  I'm using an I-Pac and testing on games like Donkey Kong, and MsPacman
Thanks for the reply.
ark_ader
  • I glow in the dark.
« Reply #3 on: February 18, 2010, 01:28:53 pm »
I think it would be more challenging for a game like pacman just to have four push buttons instead of a joystick.
JZSlenker
« Reply #4 on: February 18, 2010, 01:42:24 pm »
So for a game like pacman to disable diagonals for both joysticks I can do...
UP=UP OR R NOT LEFT NOT RIGHT NOT D NOT G
LEFT=LEFT OR D NOT UP NOT DOWN NOT R NOT F
etc etc
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: February 18, 2010, 03:25:54 pm »
How does one get the "NOT" part ? Or is this strictly done via direct editing of the CFG files?
NO MORE!!
JZSlenker
« Reply #6 on: February 18, 2010, 03:49:15 pm »
you can get the NOT by hitting the not key two times fast.
For example if you wanted up not right you would do the following....
ENTER on the UP line then press UP  RIGHT RIGHT
If you are too slow on the RIGHT RIGHT you will end up with UP being assigned to UP AND RIGHT
It's easier to edit the cfg file though if you want a more complicated line like..
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: February 19, 2010, 01:39:48 pm »
etc etc
Close.  Mame uses Ors to separate groups.  So as shown mame sees:
UP = (UP) OR (R NOT LEFT NOT RIGHT NOT D NOT G)
etc
So up-right is fine for the first group, so mame will treat stick 1 as an 8-way and stick 2 as a 4-way as long as stick 1 isn't used.
You want:
UP = UP NOT LEFT NOT RIGHT OR R NOT D NOT G
LEFT = LEFT NOT UP NOT DOWN OR D NOT R NOT F
A little more human readable:
UP = (Up not Left not Right)   OR   (R not D not G)
I find hand editing the cfg easy too, but using mame's UI isn't too hard for those who like GUIs, either.
The map I suggested:
For UP: enter, up, right, right, left, left, wait about 1 second for mame to register, R, D, D, G, G, wait.
(repeat for other directions)
OTOH, I will often most of the above in a test editor.
Robin
Knowledge is Power
