Author Topic: paperboy handlebar MAME hookup  (Read 7234 times)
jcterzin
  • Last login:May 08, 2012, 02:02:15 am
« on: February 17, 2010, 12:50:37 am »
So... Anyone ever successfully connected an old paperboy handlbar control panel to an ipac or so to get it to work in mame? I could potentially get a control panel from an old Paperboy but the PCB may be damaged so I was thinking I might try and mame the cab. Thoughts?
Xiaou2
  • NOM NOM NOM
Re: paperboy handlebar MAME hookup
« Reply #1 on: February 17, 2010, 03:24:25 am »
 Im pretty sure its simply 2 pots, much like a Starwars yoke.  Shouldnt be any trouble hooking
it up.   The only thing that Might be a problem would be the travel distance of the Y motion.
If its too small, it might not calibrate well in windows.
Havok
  • Trade Count: (+17)
« Reply #2 on: February 17, 2010, 10:00:54 am »
Yes - it's a couple of pots. If you can wait, Ram Controls is making a dedicated USB interface for it.
Or you have a bunch of other options:
AKI:
http://bspeclabs.com/Electronics/8-AKI30JoystickInterface
Dual Strike Hack:
http://rototron.info/default.aspx?Page=DualStrike.aspx
U-Hid:
http://u-hid.com/index.php?option=com_content&view=article&id=15&Itemid=19
« Last Edit: February 17, 2010, 10:04:44 am by Havok »
push2reject
  • Last login:January 28, 2014, 06:55:40 pm
« Reply #3 on: February 17, 2010, 10:39:16 am »
One more option:
A-PAC:
www.ultimarc.com/a-pac.html
On the other side of the screen, it all looks so easy.  -Kevin Flynn
jcterzin
« Reply #4 on: February 17, 2010, 01:28:41 pm »
Thanks for the help guys.
Havok - do you know when Ram Controls will have that USB interface ready? Sometime soon?, if not I may try one of the other options.
  • Last login:May 06, 2024, 04:33:26 pm
« Reply #5 on: February 17, 2010, 01:37:26 pm »
 :laugh2:
Necro
  • Last login:November 29, 2022, 08:22:22 pm
« Reply #6 on: February 17, 2010, 02:11:22 pm »
That was a joke right jcterzin?  :)
(Check out the other thread on just getting a Star Wars yoke...)
Havok
« Reply #7 on: February 17, 2010, 02:52:56 pm »
That is a tough one to answer - we'll see. Personally, I'd go with the AKI if you want to get it up and running now...
« Reply #8 on: February 17, 2010, 03:04:32 pm »
Or this decade...   ;D
jcterzin
« Reply #9 on: February 17, 2010, 03:05:43 pm »
why is that a joke, are they just super slow at making products?
Necro
« Reply #10 on: February 17, 2010, 04:04:48 pm »
See this thread: http://forum.arcadecontrols.com/index.php?topic=99056.0
Basically, it took awhile for them to get it from demo to actually shipping and even then it took over a month for Havok to get his yoke after they said it was shipping.  Interaction and updates were nearly non-existent. Also, he hasn't received the USB kit that was to come with the yoke yet as, correct me if I'm wrong, it's unfinished at this point. Short of that issue being completely resolved, I wouldn't recommend getting something from them not definitively 'finished' and in stock.
Just a heads up on that - particularly since other, readily available options exist.
Havok
« Reply #11 on: February 17, 2010, 04:16:46 pm »
The Star Wars USB interface *should* be complete by the end of this month. There are some issues with the firmware that need to be ironed out. Dave is making a dedicated Paperboy one as well, which is basically the same interface, just with some differences for Paperboy. With that said, the other options are available now, and Dave is at this point notorious for missing deadlines. It is understandable once you see the superior job done, but in this case an interface is an interface and I would go with something else, unless this is something that you don't anticipate being done for some time.
jcterzin
« Reply #12 on: February 18, 2010, 12:16:41 pm »
ehh, sucks but I guess I can wait.
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #13 on: February 20, 2010, 01:33:29 am »
slightly OT - how well does a star wars yoke play paperboy?
to see my "Frankenpanel" and design notes, click here.
Xiaou2
  • NOM NOM NOM
« Reply #14 on: February 20, 2010, 02:50:08 am »
 It would probably play it better than the original controller.
 Paperboys controller is very clunky IMOP.  Hard to control the acceleration well with it,
partly due to the mass, partly to the way its leveraged, and partly due to the way its
sprung.
unclet
« Reply #15 on: February 20, 2010, 02:00:23 pm »
I purchased a Microsoft Dualstrike USB Sidewinder gamepad and hack the pots to the controller.  I actually hacked about 6 of these Dualstrike gamepads and hooked everything up.
http://unclet.arcadecontrols.com/MomsArcade/MomsArcadeDualStrike.html
There is a photo link on that page as well ...
[EDIT]  The Dualstrike gamespads as very old so they might not be around on Ebay anymore.  But if some other controller exists which has 5K pots (I think it is 5K) then you can use that one I guess.
« Last Edit: February 20, 2010, 02:03:08 pm by unclet »
RobotronNut
« Reply #16 on: February 21, 2010, 11:11:30 am »
i haven't played paperboy in a long time, but my recollection is that i was always either trying to go as fast as possible or as slow as possible. so no need for an analog controller at all; a simple switch would have worked just as well! then again, i was never that great at paperboy...
Daviea
  • Trade Count: (+30)
  • Last login:December 10, 2010, 06:51:56 pm
    • RAM Controls
« Reply #17 on: March 21, 2010, 08:49:01 pm »
FYI, in case some of you have not noticed yet, the USB adapters ARE ready and they're shipping!
http://forum.arcadecontrols.com/index.php?topic=101145.0
Enjoy!!
Dave
jcterzin
« Reply #18 on: March 23, 2010, 10:16:21 am »
wow, this makes me almost want to swap out the pcb and other stuff out of my paperboy and run mame in it.
