Author Topic: how easily do carriage bolts rust?  (Read 1354 times)
Jefferson
  • Last login:January 14, 2024, 08:50:59 pm
« on: February 16, 2010, 03:23:19 pm »
Because of my weird partially hollow CP I need the carriage bolts on top. I sanded the numbers off em and they look great. Then I heard to avoid rusting they should either be painted (nah) or clearcoated, but my clear coat must have been weirdly thick cause I dipped the head, shook the excess, and it was still wicked thick and dried all lumpy and weird. I rolled it on and it killed the 'touchless' finish.
Should I just look an another brand of clear coat? Has anyone tried anything like Future floor wax?
Should I even be that worried about rusting in the first place?
J
garnerb350
    • Hyperspin
Re: how easily do carriage bolts rust?
« Reply #1 on: February 16, 2010, 04:08:00 pm »
Werid with teh paint you used...never seen that...
Floor wax, would probley degrade over time...faster than clear coat I guess...instead of using floor wax, see if your wife/girlfriend/etc happens to have clear fingernail polish...if you already have the wax...try it..shouldnt harm anything...
As for the rust issue...long as you have the cab in a moisture free area, you should be ok...
t3design
  • Last login:January 13, 2024, 07:19:01 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
« Reply #2 on: February 16, 2010, 05:14:41 pm »
get stainless steel carriage bolts. They are not much more expensive at a local hardware store, shouldn't have any numbers on them in the first place. Polish them on a polishing wheel and they should stay that way for a very long time.
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: February 16, 2010, 06:29:56 pm »
+1
Or use a spray clear coat ... and clear nail polish doesn't sound like a bad idea.
Working: Not Enough
Projects: Too Many
Progress: None
bkenobi
« Reply #4 on: February 17, 2010, 11:15:06 am »
If the bolts are near where players will put hands, you can guarantee salt water contact (sweat)!  I used zinc bolts and just accepted the marks on top.  They don't look spectacular being there, but they shouldn't rust for a while!
If I had it to do over, I'd probably go with stainless and sand them down like t3design suggested.
Jefferson
« Reply #5 on: February 18, 2010, 04:23:22 pm »
I have some minwax polycrylic, some minwax water based (oil modified!) polyurethane, and some spray can minwax water based (oil modified!) polyurethane (which I just used on my CP and it looks sooooo cool.)
Would poly work on metal though? or is that not the right kinda clear coat? I suppose I should really trial and error this stuff like I've done every step of the way.  :banghead:
