Main > Main Forum
Help me Jamma wire for the first time...
CheffoJeffo:
Powering the monitor is someplace where you can do some damage -- particularly vis-a-vis isolation transformers.
Rather than confuse you with semantics, can you post some pics of how things are hooked up ?
slapaham:
--- Quote from: CheffoJeffo on February 15, 2010, 04:14:27 pm ---Powering the monitor is someplace where you can do some damage -- particularly vis-a-vis isolation transformers.
Will do in a little while... :cheers:
BobA:
A jamma cab will not have 24v in the ps. Where are you getting the 24V supply voltage?
slapaham:
It's a terminal on the arcade PSU I bought... I've never heard of that either!! ???
slapaham:
Just to add - I tried the solution that I suggested and it worked spot on. As the cocktail has one of those giant, ancient transformers it might be a good idea to have 2 psus running things. A modern PSU for the jamma side of things and the ancient PSU for running the monitor at the correct voltages, etc. I've read up on old PSUs varying in what they output and so rather than faff and tempt fate I think sticking with it is for the best.
Now that I have it up and running, it's just a case of making it nice and tidy. A 2way power adaptor inside will make it neater. As this cocktail table is pretty ancient, I think this is probably the most sensible way of approaching it.
