Main > Everything Else
My $13 ebay keychain camera.
<< < (10/18) > >>
RayB:
Got mine today. I think I'm charging it right now. I'm not sure if it is chargning :dunno  I LOVE the engrish that came with this thing. I didn't realize all the extra uses this thing had:
"It has small contour design, which does UV spray finishing for the whole body." - No more need for sun block!
"When you charge it, green light and red light will bright simultaneously, of which states are stillness." - It helps you with your meditation! (btw, all I see is one orange light ???)
"Notice: when battery power is not enough, K808 will enter into protection mode, so it cannot be turn on. Now, please charge for it." - Sounds like my ex!
HaRuMaN:
Green + Red = Orange when adding LED lights.
RayB:
Well, if orange means charging... mine's STILL charging.
The instruction booklet mentions software on a CD. I got no CD. Do any of you know where to download it?
ahofle:
--- Quote from: RayB on March 03, 2010, 03:14:03 pm ---"Notice: when battery power is not enough, K808 will enter into protection mode, so it cannot be turn on. Now, please charge for it." - Sounds like my ex!
 :laugh2:
RobbyMac:
Finally, got mine in.
I did some searching and found this huge honkin thread about this camera.
Looks like you can install a webcam driver for it on this page
http://www.rcgroups.com/forums/showthread.php?s=a9d9ccb7b3595c2418a31363edf93556&t=1115052&page=134
EDIT: It appears this driver is not needed unless you want to use it as a web cam.
FOund alot more info here: http://www.chucklohr.com/808/
Mine are still charging and I don't have any micro sd's here at work with me, so I won't be able to test until this evening.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
