| Main > Main Forum |
| aimtrak help? |
| << < (2/2) |
| sham69:
Thats what I tried but wasnt sure? I press the trigger for 5 seconds, top left and top right click ok but then the cursor goes to the bottom middle of the screen and keep going up and down? Nothing I click will stop it. I am quiting for today as have spent about 10 hours on this today. Will try again after work tomorrow. Thanks for all your help. I am sure its going to be great once I get it working as it seems to be a great product. |
| kjbalto:
If you're getting arrows to the left of your screen and you're shooting in the left corner and then it moves to the right and does the same, that's what it's supposed to. When it moves to the bottom part of the screen, if it's not taking your shooting, you're shooting too far off screen. Move your gun up a little bit to shoot. Once you successfully do the sides and the bottom, it will be calibrated and you can move the gun around. |
| sham69:
bottom won't calibrate no matter where I point it? |
| tdkc:
Your not the only one thats had issues calibrating. I had the same thing happen to me. I just adjusted the LED board by pointing down a bit then re-calibrated. |
| sham69:
thanks for the replies guys. I am sure its only a hiccup and will try adjusting the led's when I get home. I don't have a permanent position for the led board yet so its not a big deal to change it. I might try to get it in behind my marquee. Thanks again. |
| Navigation |
| Message Index |
| Previous page |
