Author Topic: Ultimarc UltraLux chrome button insert  (Read 2990 times)
Charlie97L
  • Last login:July 03, 2017, 03:35:56 pm
« on: February 05, 2010, 11:08:11 am »
how do you open this to put the insert in?  i got one to use as a coin button on my bartop, and for the life of my cannot figure out how to get it open.
this is the product to which i am referring...
http://www.ultimarc.com/ultralux.html
thanks guys!
Havok
  • Trade Count: (+17)
Re: Ultimarc UltraLux chrome button insert
« Reply #1 on: February 05, 2010, 12:39:42 pm »
I don't have them, but I imagine they would be similar to Happs buttons. There should be two tabs on the bottom of the button, that actuate the switch when fully assembled. Push the tabs in towards the center of the button, and at the same time push up. This should pop the button out of the housing allowing you to put in an insert.
Here's an exploded view to give you a better idea:
« Last Edit: February 05, 2010, 12:44:27 pm by Havok »
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: February 05, 2010, 12:44:09 pm »
Remove the button plunger from the assembly and there is a cap on the end. Pop it off, install the insert, and put the cap back on.
Encryptor
  • Trade Count: (+34)
« Reply #3 on: February 05, 2010, 12:50:25 pm »
The Ultralux buttons are lighted so you'll have to pull out the socket (should just pull straight out) for the bulb before you can get to the plunger and remove it similar to the diagram Havok posted. The Ultralux micro switches are mounted horizontal instead of vertical.
Encryptor
Ginsu Victim
« Reply #4 on: February 05, 2010, 02:52:52 pm »
FYI, the socket doesn't come installed on Ultralux, so it shouldn't be an issue.
Havok
« Reply #5 on: February 05, 2010, 04:23:23 pm »
Encryptor
Yeah, I didn't post the horizontal one because it didn't have an exploded version. I figure if you see how the plunger portion looks, it all makes sense...
Neverending Project
    • Arcade Fixer
« Reply #6 on: February 05, 2010, 04:40:50 pm »
True 'nuff. But if it is installed for whatever reason, you will need to twist the socket about a quarter or half turn to "unlock" it before it will pull straight out.
Charlie97L
« Reply #7 on: February 06, 2010, 07:12:42 pm »
i got it thanks guys.  :)
