Author Topic: Opinion on PC needed.  (Read 1221 times)
gdilly
  • Last login:November 16, 2016, 10:33:55 am
  • www.gdilly.com
    • Arcade Ramrod - www.gdilly.com
« on: February 05, 2010, 08:50:55 am »
I am in desperate need of a new pc to run my system.  The previous one is dead and buried.  I plan on running HyperSpin or similiar type frontend.
I found this combo on newegg.  I've haven't looked into pc specs for at least 6 years and can't easy spot the good equipment/deals anymore.  Will this setup run almost everything smoothly?  Any opinions or reviews you have would be greatly appreciated.
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.328159
« Last Edit: February 05, 2010, 08:52:26 am by gdilly »
Chuck Norris was originally in Street Fighter II, but was removed by Beta Testers because every button caused him to do a roundhouse kick. When asked about this "glitch," Norris replied "What Glitch?"
massive88
Re: Opinion on PC needed.
« Reply #1 on: February 05, 2010, 08:53:54 am »
It depends on what you mean by almost everything.
It will run 98% of all mame just fine.  For some, that 2% is the deal breaker.  Ridge Racer, Gauntlet Legends, and other games this might still struggle with.
Hyperspin it should run fine, and the vast majority of games it will run fine as well.  For the price, its not a bad deal at all for a mame machine.
ShoryuKeith
  • Last login:July 26, 2017, 07:37:42 am
  • World Warrior
« Reply #2 on: February 05, 2010, 09:28:43 am »
what spec Pc would run Ridge Racer, Gauntlet legends etc without any problems?!
握りこぶしのマスター
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: February 05, 2010, 09:55:11 am »
Most.....as long as you use a PSX emulator instead.
gdilly
  • www.gdilly.com
« Reply #4 on: February 05, 2010, 03:24:12 pm »
Thanks, but just out of curiosity...
What specs are most people using?
  • Last login:Today at 08:24:26 am
« Reply #5 on: February 05, 2010, 03:55:57 pm »
alot less then that. my one MAME cab is running a P4 2.4 and the other PC Im using for futurepinball/vert mame is gonna be a dual core intel, forget the speed
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
« Reply #6 on: February 07, 2010, 03:46:00 am »
The biggest and most apparent bone of contention with this setup will be the lack of native Legacy Serial and parallell ports.
Truly, i wish that someone could tell me without a doubt what the latest and greatest legacy / usb 2.0 hardware is that will still run on windows ME Or 2000.
The only reason in this world that i upgraded to xp was because that the newest system i speced would not run under ME or 2000.
The funniest thing of all is This.
I was terribly out of date when i was forced to adopt windows 98 SE. I was also out of date when i was forced to adopt windows Me.
The funniest thing is that except for usb 2.0 the most recent changes and updates would always install under windows 95, Or 98 Se, even Windows 2000, Etc no matter what system you had.
It was in fact the same time Frame that Windows Xp was released and Product Activation Was Introduced, That it became painfully apparent even through simple upgrades that you couldnt just simply maintain your old ME or 2000 System and continue to resist Xp.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #7 on: February 07, 2010, 04:24:39 am »
Go for it.  Looks like a great deal.  It should run everything you throw at it except for those games people mentioned (Blitz, Gauntlet Legends, etc).  But as people stated those games don't run at their full frame rate on any setup at the moment.  I'm running and AMD Athlon X2 4600+ w/2 GB of RAM and it's runs MAME just fine.  Paired with a 1GB video card and you can run Street Fighter IV without issues (I can and it runs beautifully).
D
